Mr. Stryker
- Mar 15, 2005
Must be able to do 1600x1200 at least 85hz, what monitor do you guys suggest? Also make it flat panel. I don't want to spend more than 180 bucks.
There's a truck in the alley on 3rd... ahem...Mr. Stryker said:Must be able to do 1600x1200 at least 85hz, what monitor do you guys suggest? Also make it flat panel. I don't want to spend more than 180 bucks.
GilmourD said:There's a truck in the alley on 3rd... ahem...
You've got a pretty tall order for $180, besides the fact that you're asking for a CRT AND a flat panel in one... Considering that they're not similar at all... :-D So, which is it that you want? CRT or flat panel? You MIGHT be able to squeeze a 19in CRT into that budget, as long as the refresh rate isn't THAT important to you and the monitor's on a nice sale, but a flat panel will never fit into that budget... Unless you see the guy on the back of that truck. LOL
