Neither. Both are TN, which are terrible for color reproduction and have bad color shift at angles. It's hard to find a new non-TN panel under 20" these days. For graphical work, you really should get an IPS monitor, though those are considerably more expensive, in general. The Dell 2007WFP tends to be IPS, though you could be unlucky and get a VA panel instead (which would be albeit still worlds better than a TN for graphical work), or you could get a NEC 20WMGX2, though there's a chance the one you get might be refurbished (which isn't necessarily all that bad).
Not that I know of, but you can do the reverse. TFT Central has a database where you can plug in the model, and get out the panel type. You can theoretically search by panel type too, but searching for 'IPS' results in lots of TN hits also for some strange reason. There are a couple of other sites like that too.
