silverphoenix
- Feb 15, 2006
I have a trupower II 480, and according to antec's site it can provide 18A each rail. Is that enough to power the x1900xt?
looks good to me, the X1900XT 256mb is a great card. have fun with it. i will need to grab one but waiting to see if prices will fall come october.silverphoenix said:A64 3000 running at 1.55V, 1 sata hdd, A8N-E, 2x 120mm fans antec, 1x 512ddr ram stock volts, and a dual layer burner.
Arcygenical said:Get some more ram. Please!
silverphoenix said:with the prices of ram these days...
rcf1987 said:Ram and a cpu the a64 3000 isn't what it used to be
Marvelous said:Speak for yourself...You have athlon xp2400 on a A7V
a64 3000 is plenty enough... Just overclock a little...
rcf1987 said:I know my cpu sucks but I think as soon as spring of 07 comes around that a64 will be just like my 2400xp
Are you sure the rails are additive?Marvelous said:You have 36 amps... You have nothing worry about...
arthur_tuxedo said:That's not right. First off, an X1800 XT (or any card's) power draw is not even close to 17-20 A, much less the difference between idle and load. Second, insufficient power to cards doesn't cause a drop in performance, it will cause them to simply not work. There must be some unrelated factor causing the performance difference.
If your programs are telling you that it's drawing 10A at idle and 27A at load, then yes, they're lying to you. No video card draws that much. Even Crossfire XTX's aren't that hungry.S0m30n3 said:I guess rivatuner and atitool lie. When monitering the draw its more constant with the 250w 13amp and all over the place with my 18amp shared with everything. It works it just doesnt work 100%. I would like for you to read up on how much power it takes because I have spent 20+ hours reading different things on what people think.
WRONG, most aren't.blade52x said:Dual rails are additive
The A64 3000+ overclocked is plenty to push a x1900 xt.rcf1987 said:Ram and a cpu the a64 3000 isn't what it used to be
3xHard Drivesilverphoenix said:I have a trupower II 480, and according to antec's site it can provide 18A each rail. Is that enough to power the x1900xt?
