180mm Fans
Kenjiwing
DO THEY EXIST? I want to replace the 3 in my rv-02 with much higher CFM fans..
Must be black.. and support 3 fan power connectors.
Think you may be out of luck. There's a few around (Akasa, XClio for example), but they're designed with different mounting hole positions than a standard 180mm fan (think the standard for those fans is a 160x160 fan mounting hole position.
Ya.. apparently you can mount smaller fans in the case but im not sure how thats going to work atm.
