Originally posted by ScHpAnKy
definately lots of gaming, I'm sick of hauling 6 () CRT's to my LAN
Is ghosting a huge problem on the 1901FP?
looks like I'm getting a 1901FP
Originally posted by srage2k2
The ghosting is almost noticable on the new 2001FPs, but I still love them so much.
Are you still sure you prefer the 1800FP over the 1901FP?Originally posted by ozziegn
huh?
do you mean you have the 1800, 1901 and the 2001FPs?
if so, then you must know that ghosting is 99.99999% non-existant on the 2001FP. the 1800FP comes in second place where ghosting is there but it is very, very minimal.
again, if you have the 1901FP, then you know you cant even compare it to either one of the mentioned LCDs above because it does have some ghosting issues.
Because if it's really that good I'll get it instead...any idea how these monitors compare to the best Samsung 19" ?
look, here's the reason why I said what I said.
1. you said that you plan on doing lots of gaming with whatever you get. so if thats so, then I can almost promise you that you'll experience ghosting on the 1901FP. thats almost a fact. the 1901FP is a good LCD w/ a great picture display but it does in fact have ghosting issues. again, I've been there and done that.
Originally posted by FragMagnet
Hey ozziegn, quick question, can you tell me which games you noticed the most "ghosting" on your 1901FP ? The only one that I noticed out of my collection that was really bad was Half-Life. I would like to set up a few of the bad ones (hopefully they have demos, or I can borrow them from a friend for the test) before the 2001FP arrives, just so I can get a back-to-back comparison in this area.
Originally posted by gplracer
Dont listen to any one who says,
Consider he is 7
