While mATX and Mini ITX really came far, the X systems with quad channel really require ATX motherboards. However, these have 7 slots which are really rarely used these days. If you are running Tri or Quad SLI this thread is not for you.The ATX factor requirement comes from the 8 memory slots eating up the space around the socket and the (rather large) chipset needs to be in front of the slots.
Here's my thinking. Take the Silverstone LC13B as an example:
Imagine cutting off the ATX PSU on the side. Use an SFX PSU and put it on top of the rightmost three slots. You still have 4 slots left. The chassis would be practically the same footprint as the motherboard itself and taking a guess from the Silverstone case for the height, that's 170mm. Height wise the photo shows a little clearance above the 100mm PCI height, the PSU should fit. The ATX motherboard itself is 244mm long, even SFX-L is only 130mm, the remaining space on the side could be used for disks.
Airflow wise, there are two 80mm fans in the back and likely the front could see two 80mm fans too, many memory modules are less 40mm (for eg Ballistix Tactical).
Video card wise at least some GTX 970 would fit.
Is this worth pursuing?
