172x - input switch?
saqdeez
this monitor has DVI and analog, but not sure if you can hook up 2 computers and switch between them. Can anyone confirm or deny this?
Know any other possible 17" gaming lcds that can do this?
you could just find a cheap KVM switch and only hook the monitor cables to it, thats what I currently do with my two pcs and one monitor
why would i spend $600 on a monitor and then degrade it with a kvm switch?
you could get a kvm that uses dvi and not vga, then *both* your computers could feed the monitor in dvi mode instead of just one
You CAN hook up two computers to a 172X using the Analog and DVI inputs. The monitor will automatically switch OR you can manually switch them with a button press.
gro thanx!
