$170 to spend at newegg
got a $170 refund from newegg. need help spending it. Here's what I need:
Video Card For DooM III
This doesn't need to be an x800 or 6800, or even a 9800 pro. something cheap, cause I need more money for the other stuff. I also happen to prefer ATi to nVidia, but I don't care if it's built by or powered by. nice bundles are always good.
Power Supply
I have a micro-ATX case, so this is going to need to be a micro-ATX pwoersupply. it's imperitive that it's over 250w, and the more the better.
HSF
socket A athlon xp 2600+ on a DFI KM400 motherboard. I'd like to do a bit of overclocking, but my main concern is something that will actually cool my cpu {aka not stock hsf}
remember, I only have $170, but could go a little over if necessary. I like those all in wonder cards, but I know I don't have enough money for those.
thanks in advance
What do you have now? It's kinda hard to tell you what to get w/o your system specs.
Radeon 9600XT - $138
or
Radeon 9600PRO - $125
Personally I would get the XT, but that bumps the price up a bit. The 9800 Pros are still around $200, so that's right out.
Enermax Micro ATX 270 Watt - $45.65
or
Enermax Micro ATX 250 Watt - $31.50
270 watt is the biggest Micro ATX PSU Newegg has, so not much choice there.
Arctic Cooling CPU Cooler For AMD Athlon Socket 462 up to 3400+, Model "Copper Silent 2M" -RETAIL - $14
Not the greatest HSF ever, but cheap, and should be adequate.
This puts your final price between $170.50 and $198, depending on whether you buy cheaper or better.
my system specs are this(I'll put them in my sig some other time)
athlon xp 2600
DFI VIA KM400 chipset motherboard
2 sticks of 512mb pc2700 RAM
audigy 2 zs
stocks hsf
240w crap psu
actually, If I'm not mistaken, I might be able to spend the money elsewhere, also. Is a 9500 pro better then the 9600XT? i can get one for the same price.....
I don't know how you feel about Best Buy or rebates, but if you don't mind em you can get a 9800 Pro Built by ATi for $179.
He said his refurb is at newegg though, so I believe it's only good there.
yeh, plus I need to buy a bunch of other stuff too.
here's an idea:
radeon 9500pro at 140 vs radeon 96090xt at 135
what's the better deal?
I'd recommend you get this Powercolor 9800SE. Omega drivers can softmod it and unlock the other 4 rendering pipelines. Same memory interface and clock speeds as the 9800Pro, so you're basically getting a 9800Pro for $145. It may be taking a slight gamble, but It'd be well worth it.
