SurplusComputers has a 16PC Premium Precision Tool Set on sale for $9.99, $7.88 shipping.
maademperor said:100 piece dremel tool set for 9.99 too
http://www.surpluscomputers.com/store/main.aspx?p=ItemDetail&item=TOL10225
And cordless dremel for 9.99
http://www.surpluscomputers.com/store/main.aspx?p=ItemDetail&item=TOL10285
I could see these guys getting $30 from me today...
All the tools and accessories you need to cut, grind, sand, drill, sharpen, polishe and more! Over 100 different accessories available and it works on metal, ceramic, glass, wood, plastic and many other materials. Works with any Dremel or Dremel Type Electric Die Grinder. Also comes in a really cool wooden case.
The cordless Dremel Type Rotary Tool cuts, grinds, sands, drills, sharpens, polishes and more! Over 59 different accessories available and it works on metal, ceramic, glass, wood, plastic and many other materials. Compact size allows comfortable use and control even in tight places. Quick-change collets firmly secure accessories. NO TOOLS REQUIRED! High Speeds of 10,000RPM motor enables the grinder to perform many tasks that are not possible with other tools..... PLUS GET 59 pieces of accessories and mini tool kit for everything you'll ever need! Tool supports collet sizes of 1MM, 2.3MM, 3MM, 3.2MM
