16GB USB Flash Drive $49AR
Also, what read/write speed? 16GB drives in this range aren't *too* uncommon now, but the transfer speeds are usually suck.
Features
* Support Toshiba, Samsung and Hynix NAND flash memory of 1Gbit, 2Gbit, 4Gbit and 8Gbit.
* Capacity: 16GB
* Support USB specification version 2.0
* Transferring rate up to 480Mbit per second at ″High Speed″.
* Support power saving mode to reduce power consumption
* Support Windows ME, 2000 and XP without device driver
* Support Driver for Windows 98/98 SE
* Driverless solution for Linux Kernel version 2.4 or later version
* Driverless for Mac OS 9.X or above
* LED indicator when device is in use
* Hot Plug & Play
* Durable solid-state storage
* No external power is required- DC 4.5V ~ 5.5V from USB port
* It also supports software application for Disk Security and Disk Partition
That's insane how quickly flash memory dropped. So I can carry a couple of full length movies on one now.
