1600 not supported unless OC
Skulltrail
What does that mean? I've seen some MSI motherboard that don't support 1600MHz memory modules right out of the box and require overclocking. What exactly do I overclock in order for the BIOS to recognize 1600MHz RAM?
The memory controller in your processor (assuming its lga1366,lga1155,lga1156, or am3) only officially supports 1333mhz so to get 1600mhz you are technically overclocking the memory controller. You just select 1600mhz from the list of memory speeds on your mobo to achieve it.
