im not the most healthy person around but i tend spend a heck of lot of hours infront of a pc during work and when at home gaming etc. 3 years ago me legs began swelling my dock suggested i need better chairs to combat it as well as exercising. after going thru a few i got a aeron at work and a 2nd hand humanscale one at home. my legs dont swell at all any more
yes they are expensive but they are good for you to
Yes. That and like your doctor said, you should try to get regular physical activity into your life. If you aren't doing one already, here is a GREAT cardio plan, the "couch potato to 5K running plan": http://www.coolrunning.com/engine/2/2_3/181.shtml
It totally works. Just stick with it and over the course of 2-3 months it eases you from being totally out of shape to running 3 miles at a time with no problem. I started it four years ago after having not jogged since PE in high school (which I was terrible at) and now I run 12 miles a week. The key is to stick with it. If a week's program is too much for you then fall back to one you can handle until you are ready to move on.
Hope this helps!
