- Sep 5, 2001
I am aware of saphires getting successfully modded to open up all 16 pipes ..but am wondering if any of the VisionTek , Powercolor ..or any other brand X800 pro cards have been successfully unlocked ..
SnowBeast said:Well, I just checked mine before I head off to the store for materials.
It is infact one that can't be modded supposedly by this guys article.
The numbering is as follows:GB8808.1
Well, if I post today or tonight everything will have went right. If not, I probably will have shot myself..j/k Kind of nervous about this.....
M4d-K10wN said:Hmm. What brand is your card, again?
StArWaRrIoR said:I got my Visiontek X800 Pro today and tried to mod it. I went and bought a conductive pen (wasn't easy finding one) and did that, flashed the bios and restarted. I installed that ATItool which tells you how many pipes are active, and alas, only 12 were. I did everything I could think of and nothing worked. After I flashed the bios, Windows installed the Rage theater chip (odd) and it set the clock to XT speeds. It can run easily at XT speeds, but the pipes were still 12.
I am happy with the performance of the X800Pro, but it would have been nice if it would have modded to the XT.
Hopefully there will be a method of modding the Visiontek to the XT sometime soon.
StArWaRrIoR said:I didn't attempt to remove the surface of the copper... I wonder if that's why mine didn't work? It's a bit scary scraping something on a $400 video card. lol
If anyone else is in the same boat, meaning that they attempted the mod without scraping the contacts and it didn't work, post here if you get it to work after scraping them.
