Justgetmein
- Nov 20, 2005
I'm thinking of buying a nice big fast hard drive but i don't know if i need to go Raid ... better yet what does it mean to have a Raid setup or have a bigger cache.
Justgetmein said:Well i use it for games, movies, anime, music, etc.. all the normal stuff but i do download a lot of stuff so i would need at least 200gb.
This is gonna be a new rig so if i need like a special mobo then i would get it and i'm thinking about this lil hardrive WD2005JS
the thing is I don't really know that Raid and more cache does -_-, maybe you can tell me the simple version the little i know it meens that is faster thats all i know
Another convert?I(illa Bee said:I jsut went from RAID0 with 2 SATA 8mb cache drive, to a 74gb Raptor tonight, and the singal raptor is faster overall..
DougLite said:Another convert?Not beating up on you personally Bee, but I remember this post. Raptors (73GB+) are the real deal
I would recommend your OS drive be the fastest single drive you can afford, and have a second larger/slower drive for storage. All depends on your budget. Remember you can always add storage drive(s) later with very little effort. Changing the OS drive isn't quite as easy, but also very doable.Justgetmein said:one last thing should I buy a bigger cache or sacrafice it for more storage?
is cache really a big deal?
Anarchist4000 said:One thing you might want to consider is a single drive plus a raid setup. It sort of depends on how much storage space you're needing but consider something like the following.
Single Raptor - used for OS/programs/games
Raid5 - used for storing bulk files(music, video, pictures?)
