- Dec 24, 2008
Do 1920x1080 monitors usually cost the same or less than similar quality 1920x1200 monitors?
we are talking about games so 16:9 IS a wider fov than 16:10 in hor+ games.The bolded part is completely, 100% wrong. 1920x1080 and 1920x1200 are THE EXACT SAME NUMBER OF PIXELS WIDE.. FOV in games is something else entirely, but seriously, you need to stop posting blatantly false information when it comes to this topic.
You mean like a game that ignores the overall ratio, but just goes purely by resolution? The more resolution on a single axis, the more gameworld on that axis?fine, how about vert- games, is there a combination of vert- and hor+? a game that can scale both ways? like BF2 for example ,doesn't that give you both vertical and horizontal scaling?
what a senseless and rude comment to make because I already made it clear that I was referring to a monitor just for gaming and that was the context. if you need a 1920x1200 monitor for "work" then by all means get one. and I am almost 40 years old so don't assume someone needs to grow up and get a job just because you don't like what they said.
I have used plenty of 1920x1200 monitors. and you chimed in and took what i was saying out of context. it would be like me going into a car forum where someone happened to to be talking about 0-60 of two models and me saying there is more to a car than straight line acceleration. well of course there is but that person was just discussing that aspect of the car at with someone. you made it sound like I was saying gaming was the most important when that was not what I was saying.You missed this part "As far as the whole argument goes.". That means the thread in general.
What garbagemule said was not dissrespectful. He corrected something you had wrong. I chimed in because I own the displays you refered to, and it is obvious that you have not worked with them directly.
Computers can do amazing things. Gaming is only a small part of that. A lot of people in here are cutting them self short with respect to experience and pixels.
So to all the 16:9 lovers.....two questions for you.
1) If games were optimized for 16:10, would you like that more? Is it simply the game designers choice (instead of physical aesthetics) which makes you like 16:9 more?
less accuracy? lol, so that nonsense is your new complaint about 16:9 monitors?A wider FOV at ~10% reduction in resolution which means less accuracy. Good job!
no its not really bad at all. its actually pretty good because the wider the aspect ratio the wider the view for games. that is the main point of going "widescreen" after all.sounds like hor+ games are a bad thing ~.~
no one seemed to debate this, is this true? I don't know how to check because I don't know which monitors may be considered equal quality.1920x1200 usually cost 50-80 percent more.
1680x1050 cost the same as 1920x1080.
the wider the aspect ratio the more you see on the sides for properly(hor+) done widescreen games.
1) No. because you need much vertical space in games. Especially platformgames and first person/third person games.
1920x1080's do seem cheaper, but i was never sure if they were generally the same quality as cheap 1920x1200's.
because that is what this part of 16:9 debate was about. perhaps you will notice that if you look at the comments I and some others were replying to for the last couple pages. I am not debating some of that other stuff since it is common sense. you are only seeing what you want to see because I have said that small black bars on a 16:10 monitor are not an issue. you keep trying to make an argument where one doesn't exist. keep finding silly reasons to hate 16:9 all you want but at the end of the day they are a good choice for people just like 16:10 is for many people. I have way more gripes with monitors themselves than the small differences between those two aspect ratios.You already said hor+ is a proper render engine strategy. I argued why it isn't. Compensating for lack of width by increasing vertical FOV for 4:3 is superior to hor+, but like I also said, it's not quite as easy to implement as hor+.
And I'm still failing to see why gaming is the only concern for you in a discussion of generality?
lol, that reminds me that I need to replace the smoke detector batteries...My old AOC 7Klr CRT started smelling really burnt, so I had to tell my brother to invest in a new monitor. He refused until the day my dad came into his room and smelt it![]()
If you asked me: "Would you buy a 2560x1920 (4:3) monitor over a 2560x1440 (16:9)?" I'd say "yes" because I could also just do some scaling to get what ever aspect I needed.
I've said this before regarding IPS panels - by choosing the two 1080 monitors, you'd downgrade to edge-lighting, 6-bit+FRC and a panel made in China. Regardless of resolution, backlit monitors have always been a good deal more expensive in comparison to edge-lit monitors (IPS or not). So it's not really possible to make a one-to-one comparison.When we discuss 1920x1200 the choice is "would you buy a 1920x1200 monitor over two 1920x1080 monitors?".
I assume the comparison regarded an 18" (old standard, used 1280x1024) a 24", 1920x1200 and 2x20"1600x1200 - i.e. 3200x1200. But I completely lost your point, unless one is on a budget of course. Then 4x20" old UXGAs of craigslist would be far better than 16:9 or 16:10 by that logic (?)More pixels and especially multiple monitors is important for efficiency so therefor 16:9 is far better than 16:10 without any doubt.
http://www.seattleits.com/blogs/far...ncrease-efficiency-of-computer-network-users/
@Oled
Two 1920x1080 monitors will not give me more vertical space than a 1920x1200 monitor
I don't understand how you can possibly believe this drivel yourself. Are you just saying this to stir shit up? It makes no sense. The 120 pixels mean quite a good amount of extra lines of code, documentation or website visible.Not intresting. The 120 pixels is nothing compared to the increased amount of pixels with the 16:9 alternative and also multiple monitors. Two 1920x1080 monitors are far more efficient than a 1920x1200 monitor.
No matter what budget you have you will always end up with fewer pixels if you buy 16:10 instead of 16:9.
Tragically incorrect.Therefor 16:9 is far better than 16:10 because you get more pixels and possability to buy more monitors. No matter what budget you have you will always end up with fewer pixels if you buy 16:10 instead of 16:9.
The only 16:9 and 16:10 resolutions which this is really relevant for is 1680x1050 vs 1920x1080 and also 1600*900 vs 1440*900 because they are similarly priced.
What some people dont get is that just because 1920x1080 and 1920x1200 sound similar they are not the same. Its not like that you get pixels for free just because you buy 16:10. The comment that you get more pixels with 16:10 is ridicolous because no matter how you look at it you get more pixels if you buy 16:9 instead of 16:10. No matter what budget you have you will always end up with fewer pixels if you buy 16:10 instead of 16:9.
* If you have a very small budget the choices are a 1600*900 or a 1440*900 monitor. Buy 16:9 and you get more pixels.
* If you have a small budget the choices are 1920x1080 or 1680x1050. Buy 16:9 and you get more pixels.
* If you have medium budget the choices are (1920x1080 and a secondary monitor 1920x1080) or a 1920x1200. Buy 16:9 and you get more pixels.
* If you have large budget the choices are (2560x1440 + 1920x1080 + 1920x1080) or 2560x1600. Buy 16:9 and you get more pixels.
/Oled
...If you *really* need documents and coding I highly recommend flipping one or more monitors into portrait mode, as it is much more suitable to the aspect ratio. You would get a lot more vertical for your money than the +60/+60 of x1200 vs x1080 rez you keep touting -- more like +420 /+420 top/bottom (vs a x1080 high) if you flipped any 1920x rez into portrait., or +180/+180 top/bottom flipping any 1440x rez into portrait (vs x1080 high rez). Even vs x1200 high it would be +360/+360 top/bottom and +120/+120 top/bottom respectively using screens in portrait mode.
whoah there. You best be careful with that assumption.Price does not matter because people are always willing to pay for a good product. I buy monitors as frequently as I buy speakers for my stereo - not often. It's the rest of the guts that get upgraded yearly.
@garbagemule
You are not scientific. We know from scientific articles that more pixels and multiple monitors is very important for efficiency. Therefor 16:9 is far better than 16:10 because you get more pixels and possability to buy more monitors.
1600x900 > 1440x900
1920x1080 > 1680x1050
1920x1080 x 2 > 1920x1200
Your thoughts on the importance of vertical space, resolution and multiple monitors goes in contradiction to what we know from scientific articles.
The problem with you is that you just talk with your personal believes as reference. You dont have any sources and you also neglect facts. This is the Hardforum. If you claim something you need to back it up with something.
As said. Scientifically we know that more pixels and multiple monitors is important for efficiency! Therefor 16:9 is far better than 16:10 because you get more pixels and possability to buy more monitors. No matter what budget you have you will always end up with fewer pixels if you buy 16:10 instead of 16:9.
Sounds like you never did any programming in your life. Side scrolling is much worse than vertical scrolling. In this case a 16:10 is much better due to the additional width.
Try it sometime
We know from studies that dual-monitor setups can improve efficiency, yes. You are correct. "We" also know (I put "we" in quotation marks, because you don't have any experience with real world usage of PC monitors, whereas I and many others here have) from studies
Your $500 16:10 vs $250 16:9 comparisons are totally unintresting. Especially when discussing efficiency. No matter what budget you have you will always end up with fewer pixels if you buy 16:10 instead of 16:9.
$500 you say? That's funny, because over on NewEgg, as of the time of this post, they're actually selling brand new, non-refurbed 1920x1200 monitors for less than $300.00.
Here's one.
And here's another.
