I've been looking at getting a monitor for both PC usage and playing games on consoles (Xbox 360, Wii), but I'm a bit put off by the fact that most monitors don't seem to support a 16:9 aspect ratio with black bars, but instead insist on stretching the picture up to the monitor's native 16:10 aspect ratio. I find that undesirable, although luckily the stretching is not massive.
http://www.hardforum.com/showthread.php?t=1104488 -- I found this thread that lists monitors that include aspect ratio controls, but after digging a bit deeper, it seems like some of those monitors, such as the Samsung 215TW, only support 16:10 and 4:3 aspect ratios, which doesn't help in this case.
I understand that the BenQ FP241W does in fact support the 16:9 aspect ratio. In fact, the monitor would just about be perfect for me, but it's way over my budget. Are there any other monitors that do support the 16:9 aspect ratio? The 20-22 inch size range is probably what I'd want to go for.
