same issue, I ended up using rivatuner
I don't really understand the need to fiddle with fan control. What's the point? Why can't it just be left at auto?
(a cooler video card draws significantly less power)
You can save on your power bill by increasing the fan speed (at the expense of slightly more noise).
Not to mention wear and tear on your power supply and other heat-sensitive components in your case. (not too worried about my 8800 since it has a lifetime warranty)
If anything, the system will use more power to keep that fan spinning at higher speeds constantly. Not much more, but more...not less.
Ill make it short! HEAT=AMPS----------MORE HEAT=MORE AMP DRAW to push same amount of volts or Mah in this case.....If you put a dvom on your 12v lead at vid card it pulls more jiuce when hot !
