Megalomaniac
- Jul 27, 2004
just wondering, how many people are using his drive with out raid? and its working fine?
and has anyone found the TLER tool?
thanks
thanks
Megalomaniac said:just wondering, how many people are using his drive with out raid? and its working fine?
thanks
chaikovski2002 said:what is TLER tool?
Megalomaniac said:The raptor X drive 1500AHFD, does not have TLER
http://www.storagereview.com/articles/200601/WD1500ADFD_2.htmlThis time around, thankfully, TLER ships disabled by default and may be enabled via a utility for installations that would benefit from the feature.
Well, one could conceive that the TLER "feature" only shows its effects after a long time of use. Depending on the information density on your HDD, it is possible that you'd go for a long while without noticing any problems.brachy33 said:I have been using a single Raptor WD740ADFD 74GB on my DFI board with zero problems. No errors, hiccups, etc. Game level load times are excellent as to be expected.
protias said:he was asking about the 150gb raptor, not the 74gb raptor![]()
protias said:i forget who exactly said this on the forums, but he said the TLER feature was disabled unless it was turned on by the sata raid controller.
brachy33 said:This does not appear to be the case for the ADFD drives as per WD tech support.
protias said:ok, according to the gentleman i just talked to, the 150gb raptors are fine running as a single drive. he also said the TLER cannot be disabled.
I doubt that. My and myprotias said:he also said the TLER cannot be disabled.
brachy33 said:As was mentioned before on this forum (I believe by drizzt81), TLER might not pose as a problem now, but may begin to cause issues down the road due to the nature of how TLER operates. I don't know if I feel like dealing with that 'thought' in the back of my mind and the possible file corruption problems later on...
drizzt81 said:While I am flattered that you remembered my post, I must add that I was speculating (reasoning?) about the effects that TLER could have. I am no HDD engineer, nor do I work at WD. If WD says that it's fine, I'd somewhat believe them, however they are interested in selling their products. In the end, it's a judgement call: Do you believe what they told someone over the phone or what they wrote in an e-mail? Note should it ever come to a lawsuit over this issue, the latter can 'easily' be used as evidence, an alleged phonecall less so.
