Gaming, media, web, office, etc
$1500
3) Where do you live?
Wisconsin
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything including periphials
None
6) Will you be overclocking?
Yes
Looking at 1920x1200 or 1920x1080
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None that I can think of
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 7 RC
Parts I am thinking of:
GIGABYTE GA-EX58-UD4P
http://www.ewiz.com/detail.php?name=MB-EX58U4P
i7 920
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory + Western Digital Caviar Black WD1001FALS 1TB
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.199045
XFX GTX 275
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150364
Samsung Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
XIGMATEK Dark Knight
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
COOLER MASTER RC-690 + CORSAIR CMPSU-650TX 650W
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.200608
SAMSUNG 2343BWX High Glossy Black 23"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001317
Logitech UltraX Silver/Black 104 Normal Keys 6 Function Keys USB Wired Standard Media Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126022
Logitech MX518
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
Logitech Z Cinema Advanced USB Surround Sound System
http://www.tigerdirect.com/applicat...filiateID=DWAzxOtMbXU=-MSfasvab5KuvNGSu3w.FNw
Thanks a lot
$1500
Wisconsin
None
Yes
ASAP
Windows 7 RC
i7 920
XFX GTX 275
Samsung Black
Logitech MX518
Thanks a lot
