A coworker just asked me to build a powerful desktop that she can carry around. Budget is $1500-2000. It will be used for engineering like CAD. I told her to wait for Skylake as well as for Silverstone SFX-L 600W / 700W to power a GTX 780 ti or 980 ti. I'm leaning towards nvidia due to better power efficiency and driver updates than AMD. Any opinion is welcome. Here's my draft build and price estimate:
$205 NCase M1
$130 Motherboard
$360 Intel i7
$350 GTX 780 ti 3GB
$150 (estimate) Silverstone SFX-L 600/700W
$40 CPU Heatsink
$125 16GB DDR4 RAM (2x 8GB)
$330 1TB SSD
$40 Slot loading DVD drive
$20 120mm fans x2
$1750 total. +$300 for GTX 980 ti or Haswell-E cpu/mobo and just a bit over budget. Can definitely find deals to lower the total.
Other options:
Asrock LGA 2011 mini-ITX and i7 5820k
- extra cost and lower cpu frequency in exchange of extra cores.
- not all apps take advantage of all extra cores
- hotter than regular i7
- limited CPU cooling due to narrow ILM socket
Gaming vs Workstation card
- workstation cards have better compatibility and support, but way way more expensive
- theoretically, workstation cards would produce less errors (from what I read)
- those who have used both usually say they would have preferred getting a gaming card
CPU heatsink
- leaning towards Cooler Master Geminii M4
- no water cooling and no very heavy heatsink due to traveling (plane turbulence)
Questions:
1) For anyone here who has used both gaming and workstation cards for work (engineering), which one should I get?
2) Can the Silverstone SFX-L 500W safely power a non overclock 4790k and GTX 780 ti or 980 ti?
$205 NCase M1
$130 Motherboard
$360 Intel i7
$350 GTX 780 ti 3GB
$40 CPU Heatsink
$330 1TB SSD
$20 120mm fans x2
Other options:
CPU heatsink
Questions:
