I'm putting together a new i7 system, and want a card that will play Mass Effect, Assassins Creed, etc., with decent resolution, and features maxed.
I'd like to stay around $150 now, but I'd consider adding a second for SLI later if I want some extra kick.
I'm upgrading from an ancient Athlon 3200+ XP with only 1 gig of RAM and 6800 GT OC.
I'm planning to go 64 bit, and I may try and run the Windows 7 beta on it, if it's stable enough, then upgrade to the final when it comes out, rather than spend money to use Vista for a few months.
I'm considering a 9800 of some sort, or the ATI equivelent. Would I be better off to splurge a bit more and go with a $200-250 gtx 260 or something? How would 2 9800's (or ati equiv... 4870?) compare with 1 260?
Also, any case recommendations that will give enough room for whatever card I want to put in it, now or later? (Considering the P6T-Deluxe - open to other suggestions on that, too.)
Thanks!
Thanks!
