15 year old with a build idea... help!
Hey guy's my name is Justin, i'm 15 years old and for the last four years i've been trying to build my own computer. i;m making this computer to play high quality games and want to record them for my youtube channel. my birthday was recently and im closer than ever to finishing this thing up. i have a list of parts id like to know what you would change, what is out of date, or just what you think it could do. thanks guy's email me your feed back or reply here.
Here's the build:
motherboard: ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
ram: my causin is providing me with 16 gigs
CPU: Intel Core i5-3570K Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I53570K
PSU:Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS (CX600)
HDD: WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
GPU: EVGA GeForce GTX 660 SUPERCLOCKED 2048MB GDDR5 DVI HDMI DP Graphics Card 02G-P4-2662-KR
this is what i had in mind i'm set at a limit of around $700. thanks :D
get a solid state and maybe upgrade the gpu, but otherwise seems ok with me. are you missing something else to request specific recomendations?
i have looked into solid state drives but im fine with standard boot ups and such lie that, also i can look into the 760. id like to be able to play games at high or ultra setting so what ever i can get for a reasonable price is what ill do. thanks for the replies. ;)
The 760 2GB edition should be fine, if you're only gaming at 1080p. SSD would make your system more responsive overall and load games faster, but that's up to you. Otherwise your build looks good to me.
You're missing a case, and possibly a dvd drive,
If you plan on overclocking the cpu - a decent heatsink/fan would be useful.
Help me understand the situation.
1. What parts do you have NOW in hand?
2. What is the EXACT type of RAM your cousin is providing you? (ex: DDR3 1333MHz non-ECC)
3. I'd strongly consider purchasing used. An i5 2500 or anything around there is still an extremely potent chip and can be found for great prices.
4. I'd go cheap as possible on the case.
5. Do you have any older computers lying around the house you can use for parts?
+1 to used, a i5-2600 would be nearly as fast as the 3570.
The other option is to go for an 8 core AMD CPU.
+1 to the Nvidia 760 GPU
Or see if you can get a Radeon had 7970 in a sale, but they are normally quite expensive.
-1 to the SSD, it is not needed.
The motherboard. Personaly I would go for a MSI or ASUS motherboard.
Motherboard: ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX
Since you are using H77 motherboard, no point getting K processor as you can't OC on H77 chipset. 3470 will do just fine. Savings you made here can go towards getting a GTX760/770 instead of GTX660, as your primary aim for this rig is to play and record high quality games.
One thing I see is that motherboard isn't the best to go with the CPU you listed. The 3570k is an unlocked chip made for overclocking. The H77 based motherboard wont make use of that because of its lack overclocking functions and you will only be able to run one video card on it so no SLI or Xfire in the future. If you have no plans on overclocking and will only run one video card, its a great motherboard, but you can go with a little cheaper CPU- like the IP-3470 for only $180 bucks if you haven't already bought your parts.
Also, the General Hardware forum is where this type of question should go because you will get a lot more answers there. Danny Bui is that forums mod and he is very knowledgeable about this kind of thing. You can message him to move it there if you want.
edit: Dang it, CthulhuDreams beat me to the punch by one minute! (shakes fist)
Justin,
First off I'd like to say welcome to the [H]ardForum and good on you for wanting to build your own PC! You'll be FAR happier with the quality and bang for your buck that you'll get with building your own versus buying some cheap pre-built hunk of plastic.
Take note that asking 'what components make the best build for this amount of cash' here is sort of like asking a fat kid what the best flavor of ice cream is. You're going to get lots of varied responses, but most of them will be equally as tasty. :D
I think your build looks good... my only suggestion would be to try and squeeze in an SSD somewhere in there, even if you have to forgo buying a mechanical HDD for a month or two. Buy a previous generation (last year's model) SSD like the Crucial M4 or Samsung 830, this will save you a few pennies over buying a current model. I would say an SSD is probably the single most performance enhancing item you can buy for a new machine. It's the difference between waiting 30 seconds for a level in a game to load versus waiting 5 seconds or less.
Like I said, don't let the number of opinions and responses here overwhelm you. You're ALWAYS going to find someone that says 'Hey, this motherboard is better than that one you picked' or 'Hey, I hate EVGA because they shot my dog and club baby seals'.
If you already have the above and still have $700 to spend. A solid state is a must IMO. If you're looking to buy all that, than yea, you might not have enough to spring for the SSD.
Which games will you be playing?
Also, please tell us which exact model of RAM your cousin is giving you.
It is VERY important that the ram you use has a voltage of 1.5 volts or less.
The H77/z77 motherboards are not compatible with ram using more than 1.5v.
I would recommend getting a Z77 chipset motherboard so you can overclock the 3570k. Or do as the others recommended and get a cheaper (non-k) processor. Though, used i5-2500k's or i5-3570k's sell for around $160. But you will have to buy a decent heatsink which will cost at least $30.
The cheapest option I found is a Biostar TZ77A for $80 at newegg. The next small step up is $90 for an MSI Z77A-G41, if only for the excellent MSI customer service.
Which case will you be using?
i bought a fractial design core 1000 and a common dvd drive that i have here. i can get back to you on the ram model and i was thinking of a higher watt psu. would 600w power all of this? and blue falcon your post made me laugh and think. im researching alot on the topic and trying to get the best performance for the money i have to gather.id like to play battlefield 3 on high settig bioshock infinite and grand theft auto 4 so far.
@ 450 im looking into the ram tomorrow and i have 2 old pc's here one from the 90's and one from around 2005 i wouldn't use them for parts, due to the fact that they aren't any good.
oh! i almost forgot, i was loking into other mobo's and i found this MSI B75MA-E33 LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard with UEFI BIOS on newegg for $60
if its any good then i may go with this.
Don't discount them just yet. For a cash strapped build I always suggest being creative and/or holding out for deals.
What is the make and model number of each PC? You might be able to reuse a case and a couple drives.
i would go with the asrock you chose first over that msi.
just so you know though, micro atx motherboards dont leave much upgrade room. for instance if you decide later down the line you want to add another video card.
it would be nice to know what ram you are getting from your cousin, so we can make sure its compatible.
i would also recommend the 760 over the 660.
dont get an ssd drive, while ssd drives are fantastic, since your 15 i would suggest using your money to buy a 500gb or more hdd for the extra space.
what case are you using? you do know you will also need an aftermarket heatsink for your cpu because the stock one wont hold for gaming.
I have seen you spread this FUD several different times, and you seriously need to STOP. You can use 1.3, 1.35, 1.5, 1.6, and 1.65V DDR3 with ANY Intel i3,i5,i7 from the 1st to the latest 4th generation. Intel revised their Vdimm spec to anything I mentioned as long as you keep the IMC voltage (vtt) within .5V of the Vdimm. There are thousands of people that run 1.65V DDR3 (myself included) without any problems.
I agree with the others who recommend getting a 760. If you want to play games at high or ultra settings at 1080p your video card is important. I did see a sale for used 7970s going for about $255 the other day - that would be a significant upgrade. You might just want to keep your eyes open for one of those popping up again.
An SSD is a very nice upgrade, but you can always do that later down the line - I do HIGHLY recommend it.
I would second what others suggested and consider looking for used parts. There isn't much performance lost by going with a Sandy Bridge i5 and overclocking the snot out of it :) You can find them cheaper than the new stuff.
I don't *think* that an aftermarket heatsink on the CPU is an absolute must for gaming, but it's not a bad idea. You can find decent ones for around $30. I liked my Cooler Master 212+, looks like the new version is about $40:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
thespiffygoldfish: take some time to read this thread here: http://hardforum.com/showthread.php?t=1349433 then post in the General Hardware forum here: http://hardforum.com/forumdisplay.php?f=40. Danny Bui will surely give you some of the best suggestions offered on these forums for builds.
As for my advice, if you are going with new parts, there is little reason to go with the older Ivy Bridge CPUs than with the newer Haswell CPUs. Intel likes to keep the price points roughly the same and most retailers don't deeply discount the older Intel CPUs.
If you live near a Microcenter take advantage of their CPU+Motherboard combo pricing.
If you are dead set on a -K series CPU then spend the extra money on a Z-series motherboard now. The -K CPUs are meant to overclock but are limited unless used with a Z motherboard.
Always try to go with the latest generation of video cards that you can afford as well. So like others are saying if you can afford a 760 instead of a 660 then do it.
If used parts are okay with you, consider looking for Sandy Bridge stuff. An i5 2500k and z68 motherboard might end up costing you the same or less than just the new equivalent CPU and the performance loss isn't going to be that noticeable because the money you save can easily go toward a better GPU and even an SSD.
