15" HD Displays
Tinker68
Understandably there doesn't seem to be too much commotion over 15'' displays, so I made this to ask. I'm looking at a 15'' HDTV to use at LANs with my 360. Does anyone have any reccomendations? I was looking at this model for a few reasons:
http://www.circuitcity.com/ssm/Pola...sem/rpsm/oid/150725/rpem/ccd/productDetail.do
I only want it to transport for LAN's, I use a nicer T.V for regular gaming.
It's cheap and I'm probably going to break it eventually
It's portable
It's HD ( I know it's going to suck)
It will work with my 360
It has a 16ms rt which I am okay with
So, thank you for your comments if you have any.
Don't waste your money, get a 19" for the same price like a VX922. Get much better image quality and response time and it's not too big to carry.
agreed.
Would the Vx922 work with my xbox 360 without having to purchase any extra cables? That monitor only has RGB and DVI. I don't think 360 is compatible with DVI.
From the one you linked
"Resolution: 1024 (H) x 768 (V)"
That's not even really HD.
You'd be able to get the same thing but much cheaper with a regular 15" panel + VGA cable. I don't know if there's any true 720p displays at that size outside of laptop panels, but I haven't really looked for any either.
