- Aug 27, 2007
Need some help with which one to get. I’m planning on buy an Intel 14900K, KF, KS. Which one for gaming performance?
Thank you All.
Thank you All.
The very top end of the 14th gen is the KS with slightly higher clock speeds. The KF doesn't have an iGPU, but is otherwise the same as the K which has an iGPU.
Just be sure to immediately update your motherboard BIOS to keep the CPU from killing itself with the V-min shift microcode problem.
Get the latest available BIOS firmware update on your mainboard's maker's website.What bio update number or link.
Thank you
I disagree. It is *always* good to have iGPU for debugging or when swapping gpus.Everything arestavo said. You won't need the iGPU for gaming. The 14900KS will be slightly better than the KF equivalent, but it won't make that much of a difference if you plan on overclocking (which you probably won't). If you don't care about the extra cost, get the 14900KS, otherwise the 14900KF, then the 14900K in that order.
Same here. I won't consider an "F" chip unless it's significantly cheaper. Much of the time it's like $20 less. Not enough. Even then, sometimes my old desktop CPUs end up in my home server/NAS box. I don't want a vid card in that box. I actually kinda had my current main rig board, proc and ram penciled in as an upgrade to my home Linux server/NAS next time I upgrade. Then DDR5 prices went berserk so my home server might get a life extension to avoid buying more ram.I disagree. It is *always* good to have iGPU for debugging or when swapping gpus.
