144hz in nVidia surround
manny1222
His monitors are Asus VG278HV.
I had him test each cable on a single monitor and he was able to setup 144hz on a single monitor using the custom resolution menu. However, once surround is applied he's unable ro do it.
NVsurround can be picky. DP to DVI can also be picky. I think you're going to have a lot of issues with this and should get monitors with native DP.
