3x1080p will give you more screen space for both work and play. This also gives you the choice between 5760x1080 and 3240x1920 depending on the screens.
1440p or 1600p just works. Getting Eyefinity or surround to work on games is like pulling teeth. IMHO.
/Former eyefinity user now happily back on a single 30"er
At this point, seriously, there haven't been many games I've played that haven't worked. It's nothing like the days of the TH2Go and Matrox cards where it was impossible to find a game that wasn't a source game that just worked. Now It's built-in to many engines and the only big offenders are Call of Duty Games and Unreal-Engine Games. Plus if the game is big enough, fixes are made quickly. The WSGF is a big resource and it's free. Multi-Monitor gaming is cheaper and easier than it's ever been to setup.
It's a massive upgrade that literally expands what you see and immerses you more in the games you play. And it might just make you want to go through a couple games you've beaten again with a different perspective.
My 2c.
P.S. Best of both worlds is 3 x 30"rs... and a 4K screen above them.
You can only look at 1 screen at once thus 1 good screen beats lot's of bad screens.
Looks like a single higher resolution screen is the setup of choice. I am looking to order one way or the other on cyber Monday.
Please add 3 x 1600p that would make more sense![]()
