140mm rads
absolute_zero
i'm planning on swapping out the 120mm rad for a 140mm on my H50. mostly for long(er) term corrosion issues, and to appease my ocd style aversion to the air i can hear in the system as is...but i figure while i'm at it, why not bump up the performance a bit.
so...i guess i'm asking for your thoughts on the Black Ice GT Stealth 140 from danger den, or other recommendations for a 140.1 rad.
H50 shouldn't have corrosion problems, at least for awhile.
I don't think going from a 120mm to a 140mm on the H50 is worth your time and your money at all. If you going to do that, just drop an extra 100-150 and get the real deal which will run circles around the H50.
that's probably good advice, the "real deal" is just too much mounting/fitting hassle for the mild oc i'm planning to do (plus i like the integrated block/pump situation), and the amount of maintenance i'm not planning to do.
but i'm left wondering, is that a good rad?
It is a good rad, the black ice series are very popular and in fact, replacing the H50 rad with a decent 120mm rad has seen improvements so i ould see further with a 140.1.
