So my 140mm Aerocool Shark fan has failed (lasted less than 14,000 hours compared to their stated MTBF of "100,000" hours)
. The negative reviews were true afterall. Even though it mostly had positive reviews, it most likely means they owned it for just several months when it was working... before failing. Avoid their products if you're gonna mount it horizontally.
With that said, I need some recommendations for a pair of 140mm fans mounted horizontally. They'll be mounted at the bottom and top of the case. So no static pressure type fans. Quiet fans are preferable. LED are optional.
