I've got a PCI card with an internal 1394 connector that looks like this (ie not pins on a mobo for a panel, just a connector like you'd use for a miniDV).
The case has one of these (has the internal 1394 connector for a pin configuration, not what I have on the PCI card).
Is there a way to convert the connector on the PCI card so it enables the port on the panel?
