133MHz not working!
wuya
I have a MSI KM400-M2 v3 MOBO.
Whenever I set it as 133MHz, it doesn't work! But works fine when I set it to 100MHz!
I get this message during a clean installation:
Code:
File \i386\ntkrnlmp.exe could not be loaded.
The error code is 4
Setup cannot continue. Press any key to exit.
How do I fix this?
1.6GHz Duron.
I should get a 1600MHz with 133MHz. But with 100MHz, I am only getting 1200MHz.
EDIT: Should this be in the CPU forum instead? I didn't know which forum I should put it in. This CPU had no problem with the 133MHz on my other MOBO, so I figure this is going to be a MOBO issue.
If mods feel this is more appropiate in the CPU forum, please move it. Thanks.
