- Gaming and streaming
- $1300 max
- Atlanta, GA
- CPU, case, cooling, storage,
- 16 GB DDR3 1333 MHz RAM
- GeForce GTX 770 4GB
- 2 monitors, may upgrade in the future, but not now. Dual 24"
6) Will you be overclocking?
- No
- 1920x1080
- Within the next 30 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
- RAID would be nice, SLI may be an option in the future (but not now), USB3, SATA 6Gb/s
- Yes, Windows 7 64-bit
Just a bit more info:
- This build is for a friend
- He streams Diablo III a LOT
- He multiboxes with 4 windows usually and says that it's coming to a screeching halt unless he turns everything to the bare minimum
- His goal is to be able to continue multiboxing while playing on high graphics settings
- He believes his bottleneck is coming from his CPU while streaming
- I suggested an SSD for OS boot, an SSD for games install, and a HDD for everything else
- He was eyeing an Intel i7-4930K...but I told him to wait until I checked with you all
Thanks in advance!
- $1300 max
- Atlanta, GA
- No
- 1920x1080
Thanks in advance!
