$1300 Cad/Gaming Build, First Post
solidstig
Hello all, I will be putting a new build together in the next couple of weeks and would appreciate your advice.
I will be using the computer for Solidworks, including simulation, as well as some gaming.
It will also be used for general use (web browsing, music etc), but i dont think that's very important.
Budget is ~$1300 USD, it is flexible but I don't want to spend more than I have to.
Baltimore, Maryland
I need : CPU, GPU, Motherboard, RAM, PSU, Case, CPU Cooler
I will be reusing an Intel 240GB ssd I have lying around, as well as a Western Digital 2tb drive. Also, I will reuse monitors, keyboard, mouse, speakers, microphone.
6) Will you be overclocking?
Maybe a mild overclock, but I have no experience in overclocking and value stability and reliability over blazing speed.
I use 2 27" 2560x1440 monitors
Within about 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I would like USB 3.0, SATA 6gb/s, UEFI, RAID I suppose, also I think I want a motherboard with 8 RAM slots, but please correct me if that's a waste. Onboard video and sli/crossfire are not required
I have a retail copy of Windows 7 x64 Professional I plan on using.
Thanks in advance!
Solidstig
The 8 RAM slots would mean moving to LGA2011, which would mean a pretty big jump in prices. I won't comment if you need it or not, as I'm not familiar with Solidworks.
