1) Use hardware like an aforementioned multimeter to test a PSU, software is generally too unreliable.
2) That PSU in particular is most likely a piece of junk and you should replace it, overclocking or not.
Hey RoBo the X-Clio Goodpower 500w must be a good one it's all sold out at the Egg.
Thank's for the input RoBo, that will be right in my price range when it's back in stock.
Software isn't accurate and 11.13v your system would be unstable if it would boot.
it would boot.. I once had a defective Fortron PSU that would give way too low voltage on both 5V and 12V rails.. starting at around 8V at the 12V rail and slowly raising up.. once it got to around 10.50V, my computer would start booting up..
Units that I have verified output voltages in that range (10.5-11) on the load tester fail to boot systems.![]()
