HeThatKnows said:Somewhat due to the AC vs DC. The synchronous-AC motors you find in aquarium pumps run either direction -- the direction is chosen randomly at each startup. That means the pump chamber has to be left-right symetric, which doesn't produce as much head as a volute.
it would probably just be easier for you to shield your pump and AC feed for the pump. lets here if for aluminum backed tape(thanks for the idea blaze http://www.alienhax.us/uploads/MVC-008F.JPG) and wire mesh sleeving
