Wanted to know if anyone could help me solve an issue.
I have a media box in my living room.. specs are as follows:
All at stock speeds..don't need mega overclock for media stuff..
AMD 64 3000+
MSI Neo2 Platinum
EVGA GeForce 6600GT AGP
OCZ ModStream 450W
1G (512x2) OCZ Gold Gamer
200G PATA WD HDD
Hercules Game Theater XP
Liteon DVD-RW
I have a server in a colo that was crashing so I upgraded the hardware and RMA'd the power supply with Antec which was a 480W NeoPower. They sent me a 500 Neo HE..so I figured I would change out the power supply in my media center.. so I put the Antec in my media box... but realized I needed a 24pin power supply for my server..so I put the Antec BACK in my server and the OCZ ModStream back in my media box.. that is ALL I did..
Now my media box is crashing. It is not a reboot..it is a freeze.. Mouse/keyboard does not respond..cannot ctrl+alt+delete.. have to press reset button or shut down. The freeze happens when I startup sometimes... sometimes when I get into Windows...and sometimes when I am using it for 30-60 minutes... right now I am typing on it and it has been up for about 1 1/2 hours.
I have ran prime95 for about 2 hours and no crash.. I have ran memtest for about 6 tests (I think it ran for about 2-3 hours in memtest.. no errors..) I have ran the Western Digital diagnostic tool and it ran a thorough test which lasts 1 hour with NO errors...)
SO I was thinking it my be some sort of weird power supply issue... only because that was the ONLY think I changed...and I didn't even stay with the change.. It is the exact same power supply in the system... I have tried speedfan, mbm5, and Sandra... Sandra said the 12V was at 1.85..which is obviously bs. MBM said it was at 12.40.. which sounds very strange that I am ANY bit stable if that is right. Speedfan said the exact same thing..12.40 and didn't change. So I went into the bios and checked the voltage and it varies between 12.03..to 12.09..to 12.16. It stays in between those three values..
Is 12.16 or this weird fluctuation a possible reason it is giving me random crashes? I was never able to see what it was reading when it was 100% stable.. but I checked my server..and it stays between 11.97 and 12.03 constant. My main gaming box is the same thing which runs a 550W Mushkin Power Supply.. 11.97 to 12.05 or so..
What do you guys think?
AMD 64 3000+
MSI Neo2 Platinum
OCZ ModStream 450W
200G PATA WD HDD
Liteon DVD-RW
