TheRapture
- May 31, 2000
My 12v line is showing a drop to a steady 11.73v to 11.8v under heavy loading. The 3.3v and 5v line are good to go. Is this a reason for concern? I have no stability issues at 2.33ghz but up at 2.41ghz or so I get crashes in UT2K4....I am bumping my cpu voltage up a bit, it seems the NF-7 is undervolting. In BIOS I set the cpu voltage to 1.75v and in windows using MBM5 it shows only 1.68v under load. Should I bump the BIOS setting up a bit to try and find stability at the higher clock speed, or will that excerbate my 12v line issue...?
