Bullseye_blam
- Apr 6, 2001
The 12V rail on my PSU (an Enermax EG465p-VE 431 Watt) runs a little low when the system is under full load. The 12V rail is rated for 20 Amps. Under load, it runs consistently at 11.92V, sometimes dipping as low as 11.86V according to MBM. This isn't very low, true, but I have seen it dip lower, particularly when I overclock my machine even more (it's currently a 2.4C @ 3.3Ghz, using 1.5500 vcore).
There's nothing I can do to help this, is there? It seems that this might affect further overclocking, and I imagine that raising the vcore will only make the problem worse.
Any advice or thoughts would be appreciated.
