Simmonz
- May 14, 2008
Is it abnormal to see my +12V occasionally drop to 11.75 when running OCCT to stress my CPU overclock ?
what are you using to measure voltage?..
Just going by what OOCT lists, I don't own a multimeter.
never trust in any software monitoring tool for voltages... completely unreliable. however as said if you measure properly with a cheap tester or multimeter above you are still withing ATX specs, however just imagining it was a real case with voltage drop by stress the CPU I would change the PSU instantly as a CPU never should mean that kind of current burden to make a PSU drop. it mean that any recent GPUat heavy load (specially if overclock are taken into consideration) can drop significantly the voltage under ATX specs and damage your machine.
Go and buy a cheap tester and report back..
