+12v line too low
Bodega
im running a couple 244s on a tyan thunder k8sr with an antec true 550 eps12v power supply and my +12v line is at +11.294. there is no other hardware hooked up yet besides an 80gig drive and a couple fans. is this rail dangerously low, and if so what could be the problem? i dont have any other esp12v ps's, so ive tried running on an enermax 550w with the 20-24 pin and 4-8 pin adapters and got the same voltages.
+3.3 @ 3.403 also
-Bodega
then the bios must be bogus :) since if ur 12v rails are THAT low..ur computer wont even run :)
Well, it might run, but would crash constantly at best ;)
Verify the +12 V rail with a DMM.
is having .50 or so more than 12v okay? software on this one shows like 12.40-12.94 usually.
Uh, try reading the posts above.
Get a multimeter.
+12 V rail has 5% tolerance, so 12.60 - 11.40, though you want to stay as far away from those limits as possible.
Only trust a voltmeter/DMM.
