+12v falculation is good ?
egyteam
checking the +12v with speedfan program, I got this readings:
min: 12.04 max 12.16 average 12.10
when you compare min and max, it is about 0.12 jitter
I want to know if I am in safe side , or I have to worry about this falculation ?
I was hoping +12 falculate by atleast 0.06 jitter like 12.04 min and 12.10 max
Thank you
Do you mean fluctuation?
Those voltages look very good to me. And you should probably check with a multimeter. What is your +12V reading under 100% load?
I believe the ATX spec say that it can be +- 4%. That means that minimum it could be 11.52V and still be in spec. Of course no one wants it that low, but your voltages are definately completely normal. not even a .5% fluctuation.
With one mobo, SpeedFan said that the +12V rail bounced between +6V and +8V, but the multimeter said it was a steady +12.11. Because my HD was spinning, the latter had to be true..
