However Ryboi drills suck balls. They are flat out aweful
I disagree. I have a 3 of these and I love them. My dad used to use them at work (carpentry). Although he had a few DeWalt models he actually preferred the 18V Ryobi. He is retired now.
Remember folks, a drill is like an SLR camera: you could have the most expensive drill (i.e. camera body) ever to be created, but it's still only as good as the drill bits (i.e. lenses) that you use!
You don't need much power to drill through a computer case regardless of the material. However Ryboi drills suck balls. They are flat out aweful. I've been able to do things with my 12v DeWalt I couldn't do with an 18v Ryobi. They are just shit. I'm not saying you need a DeWalt drill for light use by any means. Pick up a Porter Cable, Craftsman, Black & Decker, or a Milwaukee. There are too many decent brands of drill out there to bother with Ryobi.
I've had absolutely no issues with Black & Decker. All the B&D's we've had at work have outlasted our DeWalts. This is just my experience though.
Dewalt is black and decker, has been for 50 years.........
Hmm, wasn't aware of this. Must have just been luck then. Thanks for informing me![]()
I have a Makita 18v Li that I paid a pretty penny for and I dropped it off of a 4 foot ladder and it hasn't worked right since. I've seen Dewalts take much more abuse. I'll never buy another Makita tool again.I just got a new Makita 18V drill/driver and impact (screw) driver combo kit from Amazon gold box a few weeks ago, love the tools. They're lighter than my corded, less powerful Hitachi and super light compared to my old DeWalt 12V drill/driver. They're not the LXT super batteries, just the normal ones, but they can use the LXT's. That should be fine though cause it came with the 15 minute quick charger for these "cheaper" batteries, it'll be pretty close to impossible to go through a battery in less than 15 minutes and it came with two batteries.
This is very true I saw a guy that I work with kill a pretty new Ryobi with a 7/8" or 1" spade bit. Their "tools" if you can even call them that are just junk.
As someone who spends 20+ hours a week with a cordless drill in his hands you just can't beat a DeWalt. The B&D branded versions are a pale imitation in my experience. Most of my work is drilling wood and driving screws, I like power/weight/runtime combinaton of the 14.4V model myself. Plenty of power for anything you are likely to ever need, much better runtime than the 12, and a good bit lighter than the 18.
