128bit vs 256bit which is better and why
CleanSlate
With the introduction of the 6600 series (gt specifically) it is a difficult thing for me personally to wrap my mind around: a 128-bit part is so much more powerfull than a 256-bit part (9800pro).
I have my own ideas and researched knowledge about which is better and why but hearing a debate is always fun :). Debate on.
~Adam
depends on the load a game or application is making on the graphics card, what part is it stressing etc..
here is how the cards match up
Fillrate:
6600GT = 4 GPixels/sec
9800Pro = 3.04 GPixels/sec
Mem Bandwidth:
6600GT = 16GB/sec
9800Pro = 21.7GB/sec
so the 6600GT has more fillrate, and the 9800Pro has more memory bandwidth, but only a 5GB/sec difference
also there are architecture differences
the question you ask is exactly what i make a point about in some of my reviews, it isn't all about clock speeds and memory bus depths anymore, its all about architecture and optimization
you shouldn't get so caught up in the little details anymore, now we have to start looking at the big picture and just testing to see which card is faster and better in games
Ahh so you think the gpu speed is the bottleneck with the 9800 pro and not the ram, considering the situation? Or do you think that the 6600gt has better b/w efficiency and thus a higher true b/w usage than the 9800pro (which could happen but doesn't seem likely)?
~Adam
~Adam
The 256-bit memory bus gives a huge increase in memory bandwidth. The reason the 6600 GT is faster is because the memory runs faster clock speed than the memory on the 9800 pro. Also the gpu on the 6600 GT is faster clock speed wise and the gpus architecture is better. So the 9800 pro might have a little bit more memory bandwidth the gpu on the 6600 GT makes up for it. Check out these benchmarks between the 9800 128-bit and 256-bit versions. http://www.digital-daily.com/video/ati-radeon9800se/index03.htm
I would not say that is the answer at all.
I think you misunderstood me. I also said "Also the gpu on the 6600 GT is faster clock speed wise and the gpus architecture is better." I think I kinda simplified it too much :p .
