OK,
I decided if i'm going to upgrade my current 2.66ghz p4 w/ gigabyte sinxp1394 mobo using generic ram
i might as well go with latest stuff
as i'm not going to change it again for nother 1-2years as i've had this system for year and half now
i already have a monitor (Samsung SyncMaster 191T 19" LCD
I currently have a logitech elite pro keyboard w/ logi MX700 (waiting for MX1000 to be bundled with a keyboard b4 purchasing)
I currently already have a sounbaster audigy 2 platinum sound card
I currently already have a Logitech Z-680 5.1 THX certifed sound system
I currently already have a HP PSC2210 All-In-One Printer
i picked out some items both on intel and amd side
if you going to change anything on either list feel free to do so and also which of 2 that you'd choose
now i got couple questions:
1) how long (tech wise, etc) would these systems last?....
2) of course i'm going to be overclocking
no way gone spend $600.00+ on cooling system and not overclock so.... Which would give me the best high performance overclocking wise (i'm going to be mostly DVD authoring, encoding, transcoding, converting, mp3ing, burning, heavy duty multi-tasking, Quickpar recovering, extraction, and compressing.
here are the 2 systems
1) AMD - If i go AMD i will buy the CPU, Mobo, and dvd burner for now and buy the rest of system as i get money
2) Intel - if i go Intel i will buy CPU, mobo, dvd burner, and RAM now and buy rest later as i dont currently own DDR2 ram
Thanks for your input!!!!!!!
AMD System
CPU: AMD Athlon 64 3500+, 512K, L2 Cache, Socket 939...........$271.00
Motherboard:GIGABYTE GA-K8NF-9 nForce4 Motherboard..........$150.00
Ram: OCZ EL DC Series Gold Edition 1GB(512MBx2) DDR pc4400..$325.00
DVD Burner: Sony DRU710A.....................................................$92.00
Hard Drive1: Western Digital 36.7GB 10K RPM SATA Hard Drive..$110.00
Hard Drive2: Western Digital 36.7GB 10K RPM SATA Hard Drive..$110.00
Video Card: SAPPHIRE ATI Radeon X700 PRO Video Card..........$203.00
Total Cost (includ Shipping) =.................................$1261
Intel System
CPU: Intel LGA775 Pentium 4 550 3.4 GHz...............................$281.00
Motherboard: ABIT "Fatal1ty AA8XE" 925XE Motherboard..........$248.00
Ram: Corsair XMS2 Pro Series DC Kit 1GB(512MB x 2) DDR2 PC2-5400..$385.00
Video Card:SAPPHIRE ATI Radeon X700 PRO Video Card...........$203.00
sub-Total Cost (includ Shipping) =......................$1429.00
P.S. Going Peltier
I currently already have a dual slot floppy resevoir
I currently already have a black ice radiator
I currently already have a black ice pro radiator
I currently already have a meanswell 320 pelt PSU
I currently already have a ehiem water pump
should i go 360w pelt waterblock or go water chilling via swiftech MCH-452? http://www.sidewindercomputers.com/swmc45thlich.html if i go 360w pelt i will need the 600w meanswell PSU
if i go waterchill i will need a 2nd 320w PSU and a waterblock or maby put 360w pelt on CPU and use waterchiller to run water thru it?.... dont know if that would be sufficient worth the cost vs just going one or either
WaterBlock: Dominator Pro 360 Watt Qmax TEC Waterblock:...........$200
PSU: Meanwell SE-600-24 600W:....................................................$175
GPU: Swiftech MCW50-T:...............................................................$75
Black Ice Xtreme III Triple 120mm Radiator........................................$135
Tubing, clips, misc items................................................................$50
Sub-Total.......................................................................................$635
AMD System
Intel System
P.S. Going Peltier
