I was gonna get a 680LT board, so just because of that CPU it wont allow SLI to work? I don't see how a CPU could effect that.
Now if I go with a QX6850 instead, that is SLI certified, what SLI mobo will support 1333fsb?
The 9650 is a Yorkfeild is right?
I don't upgrade as often as I used to do so it means I have to replace the whole lot when I finally do, just like the current socket 939 system in my sig.
For the new system I have the following priorities:
1, 100% system stability.
2, powerful enough to handle a 30" Dell.
3, 4 cores as I normally run multiple clients of EVE-Online.
So with the currently available hardware I'm stuffed regardless what path I'm going.![]()
The new 780i / 790i chipsets should support it.
But they've been delayed because Intel want's to license Nvidia's SLi code and Nvidia doesn't want to share.
So the only way is to get a board with an Nvidia chipset - and the nF4 was the last one that didn't suck.
Here's hoping that the new chipset isn't as bad as the 680i is.
why is the view so much that 680i sucks? I love my 680i board.
and my experiances with a bunch of Nforce 4 boards were terrible.
