120mm in Chieftec Dragon?
mattthemodder
I just bought (With my new A64 System) a 120mm Fan with a 80mm>120mm converty piece of overpriced plastic.
Now, where is it gunna go? Theres a place for a case fan on the side of the PC that it could probably fit without touching my Arctic Silencer, but would it be better to stick it in one of the normal 80mm fan holes? I could drill holes because those convieneient if you have 80mm fan holders will get in the way.
Any ideas? Somebody must have done one in their Dragon
