120mm hole?
DaMaDo
Should I use a 4.5 or a 5 inch holesaw to make the hole? I believe 120mm= 4.72 inches. So its almost in the middle...should I go smaller or larger?
go smaller with the 4.5, the 5 might leave visible space between metal and fan.
I just bought a 3" Hole Saw thinking it'd be big enough.
Nope, too small. Looks like I'll be using the Dremel to grind it out to the size I need.
Good thing it's plastic...
