Retsam
- Sep 2, 2005
Any helpful info or suggestions are appreciated.
Looking for a few 120mm fans. I have little experience with 120mm fans. I am not really sure what I want. I just want a couple 120mm fans with high airflow and low noise. Silence is the priority, but I need the airflow as well. From my research it seems like Yate loon/Nexus are highly regarded. Coolermaster seem to be decent.
The fans I have been looking at:
Yate loon $3.99 at jab-tech and Tekgems yate loon
Cooler master 120mm SUF-S12-EB $6.00 shipped
Are these CM fans good? Anyone have any? They seem to have a good cfm/noise ratio similar to yate loons.
Which fans would you pick? The CM's or yate loon?
Thanks. Any info is appreciated.
