120mm fan recommendation
Fester
I’m looking to buy some 120mm fans for my case and as a replacement for the stock fan that comes with the Hyper 212 EVO. I definitely want them to be quiet and I heard Scythe was the best. Which Scythe model should I get?
Scythe gentle typhoon is generally considered the best fan for heatsink/radiator use.
The gt is made by servo, not scythe if I'm not mistaken
I have a bunch of ap15 best fans
I will agree with the Gentle Typhoon statement. They are great on my 360 radiator. I also have Scythe Slipstreams for the actual intake and exhaust fans and those work great. But since your putting it on the heatsink I would go with the Typhoon's. They are $$$ but work great and stupid quiet.
The Scythe GT are great fans, but these San Ace are the fans they wish they were :D
edit: I've been using the San Ace for nearly 2 years now and still say they're amazing heatsink/rad fans.
