120mm Fan Opinion
Siiig
Sup Guys,
Currently have a pair of XFX 6970's running in my computer. My case has 2 120mm fans on the front.
The 6970's fans are so loud, I don't think using a high flow 120 would cause much of a difference in noise. I'm wondering if the increased airflow straight onto the cards might let me clock back the fans on the cards to a more manageable nose level.
Anyone have an opinion on this?
If you think it might help, I'd love some suggestions on high flow 120mm fans. I've seen some suggestions on the forums such as the Thermalright TY140 or the Scythe Gentle Typhoons, but they are mostly suggestions for water cooling radiators. Not sure if it makes much of a difference that I'm looking to pull air into the whole case or not.
what fans are you currently using?
i wouldnt expect that much of a difference.
