I have a perfectly good gaming rig that I intend to use for a while still, but I just can't take the Vantec Tornado noise on the heatsink any longer. Rather than switch out a great heatsink, or change to the normally suported 92mm fan, I thought I'd go for real quiet with a 120mm fan. I have pretty good room in my case, so I am going to try to mount a 120mm fan on my Swiftech 462-V heatsink using an 80 to 120mm fan adapter. The adapter is about an inch thick, but I have clearance between the heatsink and the case window. The only issue will be on the top, because on the NF7-S, the CPU is toward the top of the mobo.
I grant this is a bit different, but if it works, I will post some pics here and report on the temps.
Anyone have any comments or opinions on this?
